"ERROR: could not add peer " in CME
Nov 3rd, 2009
Iam not able to add ephone-dn when i add error displayed as"ERROR: could not add peer"
What causes this is it Memory can anyone explain in detail ?
Hari
Overall Rating: 3.5 (2 ratings)
Paolo Bevilacqua Tue, 11/03/2009 - 07:51
This is a bug (memory leak) I've meet many times, but never got an ID for.
Only workaround is to reload the router. I haven't seen it happening in recent versions.
jgross Tue, 11/03/2009 - 08:21
Hello Hari,
i had the "same" problem. We updateded a CUCM form 6.1.2 to 7.1.2. So we also updated the SRST Gateways to 12.4(24)T1.
After this our 3825 Gateways with 256 MB Mem refused the command max-dn. It still worked, but only for very low numbers. (up to 23). So I opend a TAC Case and the anser was
The system is now
telling you that there is not enough memory to add dial-peers into the
system. Note that the threshold is 80% for 256M or less, 85% for
256-512M and 90% for > 512M of processor memory. The system will not let
you add ephone-dn's (dial-peers) when it's available processor memory is
below that threshold.
Below is two relevant URL that discuss this:
How to determine the maximum number of dial-peers that can be configured
on a router
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K34857008
When calculating the memory requirements for the number of dial-peers
required you can use the following:
Router>show memory summary
Head Total (b) Used (b) Free (b) Lowest (b)
Largest (b)
Processor 60AB4ED0 5550384 2082996 3467388 3464996
3454608
I/O 40000000 16777216 1937280 14839936 14839936
14838908
Total = the total amount of memory available after the system image
loads and builds its data structures.
We also saw in the following document that 512 MB of memory are recommended.
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/requirements/guide/srs71spc.html
Bye
Jo
