Please help verify rate-limit command
Answered Question
Nov 3rd, 2009
We have a partial DS3 circuit that is 18Mb. We have four facilities that connect through an IPSEC connection on this DS3. Three of these facilities just connect to us for green screen however yesterday our forth facility maxxed out the connection so I want to put a rate limit their connection.
I am looking to put a cap of 14Mb, this will keep 4Mb free while also triggering the 75% utilization alert should the main facility be maxing out their rate-limit. I believe this command should perform the actions that I require:
rate-limit input 10000 2000 4000 conform-action transmit exceed-action drop
rate-limit output 10000 2000 4000 conform-action transmit exceed-action drop
Should be ~10Mb normal bandwidth, burstable to ~12Mb and cap at ~14Mb. Does this command look correct?
Thank you for your time.
Correct Answer by Giuseppe Larosa about 7 years 4 months ago
Hello Eric,
be aware that rate is expressed in bps so 10000 means only 10 Kbps.
see command reference
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_q1.html#wp1054922
you should use
rate-limit output 14000000 2625000 5250000 conform-action transmit exceed-action drop
the recommended rules to dimension buffers are:
normal burst = configured rate * (1 byte)/(8 bits) * 1.5 seconds
extended burst = 2 * normal burst
see
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/polcing_shping_oview_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1000977
However, you could consider a less aggressive policy that is to use outbound shaping.
policy-map shape_all_14Mbps
class class-default
shape average 14000000
! here rate is in bps
see
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_s1.html#wp1060033
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 11/03/2009 - 08:25
  • Hall of Fame,
    Founding Member
Hello Eric,
you should use
see
class class-default
see
Hope to help
Giuseppe
randhir.singgh1 Wed, 05/11/2016 - 19:04
I configured outbound shaping:
DKG-NthSydney#sho policy-map
  Policy Map Corp-Shape
    Class class-default
      Average Rate Traffic Shaping
      cir 19000000 (bps)
DKG-NthSydney#sho policy-map interface fastEthernet 4
 FastEthernet4
  Service-policy output: default
    Class-map: default
      20639677 packets, 18379225189 bytes
      5 minute offered rate 1032000 bps, drop rate 0000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/9013/0
      (pkts output/bytes output) 20630664/18366374824
      shape (average) cir 19000000, bc 76000, be 76000
      target shape rate 19000000
But there is still congestion in network. I check with ISP who advised that link is jumping upto 80 MBPS. Not sure why policy-map not working.
