CCM4.3(1) upgrade to CCM4.3
sunishnair Tue, 11/03/2009 - 08:14
For this up-gradation, you need to download latest Service Release from Cisco Site with the help of your CCO login Privilege.
Before installing the service release you need to check this SR release matching with your existing version.
that u can find from the release notes.
Latest Service Release 4.3(2)SR1c
http://tools.cisco.com/support/downloads/go/PlatformList.x?sftType=Unified+Communications+Manager+Updates&mdfid=280771554&treeName=Voice+and+Unified+Communications&mdfLevel=Software%20Version/Option&url=null&modelName=Cisco+Unified+Communications+Manager+Version+4.3&isPlatform=N&treeMdfId=278875240&modifmdfid=null&imname=&hybrid=Y&imst=N
CSA 3.0(9)
http://tools.cisco.com/support/downloads/go/PlatformList.x?sftType=Security+Agent+Policy+Software+for+Unified+Communications+Manager%2FCallManager&mdfid=280771554&treeName=Voice+and+Unified+Communications&mdfLevel=Software%20Version/Option&url=null&modelName=Cisco+Unified+Communications+Manager+Version+4.3&isPlatform=N&treeMdfId=278875240&modifmdfid=null&imname=&hybrid=Y&imst=N
Security Agent System Software for Unified Communications Manager/CallManager
http://tools.cisco.com/support/downloads/go/PlatformList.x?sftType=Security+Agent+System+Software+for+Unified+Communications+Manager%2FCallManager&mdfid=280771554&treeName=Voice+and+Unified+Communications&mdfLevel=Software%20Version/Option&url=null&modelName=Cisco+Unified+Communications+Manager+Version+4.3&isPlatform=N&treeMdfId=278875240&modifmdfid=null&imname=&hybrid=Y&imst=N
Sunish
Hi Sunish,
Yes i already download all thing that you mention. Before upgrade I will perform backup.
I just have to double click the CCM4.3(2)SR1C then follow instruction from the scrren until finish maybe require reboot. Then continue with the CSA and CSA policy upgrade.
Correct me if I am wrong. Is Cisco provide any guide for this?
Jaime Valencia Tue, 11/03/2009 - 08:40
  • Cisco Employee,
  • Hall of Fame,
    2011
It's a wizard as the one you use to install anything on a PC.
Just run the program and follow the instructions.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
