re-establishing int BVI
miklafferty
I have a BVI interface that lost it's session overnight. I just had to shudown and no shutdown the interface. Is there a setting that will automatically restart the interface?
Giuseppe Larosa
Hello Mik,
a BVI is a virtual L3 interface to be used with IRB to provide layer services to a bridge-group.
may you explain what you mean with
"a BVI interface that lost it's session overnight. I just had to shudown and no shutdown the interface"
do you mean you had IP connectivity issues in reaching the BVI's ip address?
session is usually used with PPP but in that case I would expect a virtual-template or a multilink PPP bundle interface.
Hope to help
Giuseppe
Giuseppe,
Yes, I am using a bridge IRB over a multilink PPP. The bridge was up for 5 hours when it crashed and didn't come back up till I restarted the BVI interface. Following are the options I am currently using.
interface Multilink1
ip add xxx
ppp multilink
ppp multilink group 1
bridge-group 1
end
interface BVI1
ip address xxx
keepalive 5
bridge 1 protocol ieee
Mik
Hello Mik,
I would expect only the BVI to have an IP address and the multilink to be a member of the bridge-group with no ip address.
I did in this way everytime I used IRB (for DSL bridged RFC 1483 termination for example).
However, I don't think this is an issue because in other examples in CCO for example on FR serial interfaces this is done.
Hope to help
Giuseppe
OK. I'll give that a try. Thanks.
