Port Channel
Nov 3rd, 2009
Hi All:
I have port channel configuration on 4500.
I see input and output rate on the physical interface but not on the logical interface (portchannel).
Any idea why is this behaviour.
#sh interfaces port-channel 50
Port-channel50 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0014.a90b.c4ce (bia 0014.a90b.c4ce)
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is N/A
input flow-control is on, output flow-control is unsupported
Members in this channel: x,x
Last input never, output never, output hang never
Last clearing of "show interface" counters 1d03h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
4589587589 packets input, 5566463916855 bytes, 0 no buffer
Received 77 broadcasts (0 multicasts)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
1535337783 packets output, 260332692367 bytes, 0 underruns
0 lost carrier, 0 no carrier
#sh int Gix
GigabitEthernetx is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0014.a90b.c4b8 (bia 0014.a90b.c4b8)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 2/255, rxload 13/255
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is on, output flow-control is on
Last clearing of "show interface" counters 1d23h
5 minute input rate 52414000 bits/sec, 9493 packets/sec
5 minute output rate 8385000 bits/sec, 4996 packets/sec
1671067266 packets input, 1159009005181 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
831460771 packets output, 159495755200 bytes, 0 underruns
Chao
Vishwa
Giuseppe Larosa Tue, 11/03/2009 - 11:10
  • Hall of Fame,
    Founding Member
Hello Vishwa,
what IOS image and what supervisor model are in the box?
post
sh ver | inc image
sh module
it may be related to the IOS version and it could be just a problem related to show commands.
is the port-channel working correctly?
Hope to help
Giuseppe
vishwancc Tue, 11/03/2009 - 20:54
Hi Giuseppe,
cat4500-entservicesk9-mz.122-40.SG.bin
Mod Ports Card Type Model Serial No.
1 6 Sup V-10GE 10GE (X2), 1000BaseX (SFP) WS-X4516-10GE JAE11043J3T
2 6 Sup V-10GE 10GE (X2), 1000BaseX (SFP) WS-X4516-10GE JAE11043YUK
3 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE0814AY91
4 24 10/100/1000BaseT (RJ45) WS-X4424-GB-RJ45 JAB063607CG
5 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE0932HSGW
Yes the port channel is working fine.
Chao
Vishwa
