issue with vpn client and certificates
Nov 3rd, 2009
I have a router 2811 and a vpn client 5 and I want to auth client with certificate. After almost 4 days of researching on google I didn't find any howtows regarding my problem. All are with PIX/ASA equipments.
When I insert the token, I select the right certificate and click connect. The token ask me for PIN and the is disconnecting. The token is enrolled on a xp station with smartcard template certificate.
the enrollment server is a MSCA and is subordonate, not ROOT CA. In the attached file is my config. Any advice is welcome.
Thanks in advance.
