Multiple networks for outside connection
Nov 3rd, 2009
I'd like to configure 2 networks for outside connection so that I can assign diffirent IP's to the inside hosts.
The interface configuration is as following,
interface Ethernet0/0
no nameif
no security-level
no ip address
interface Ethernet0/0.1
vlan 10
nameif outside1
security-level 0
ip address x.x.x.2 255.255.255.192
interface Ethernet0/0.2
vlan 20
nameif outside2
security-level 0
ip address y.y.y.2 255.255.255.224
interface Ethernet0/2
nameif inside
security-level 100
ip address 172.16.1.1 255.255.255.0
When I added either
route outside1 0.0.0.0 0.0.0.0 x.x.x.1 1
or
route outside1 0.0.0.0 0.0.0.0 y.y.y.1 1
x.x.x.2 on outside1 is reachable from Internet but y.y.y.2 on outside2 is not.
I tried to add
route outside2 0.0.0.0 0.0.0.0 y.y.y.1 1
But ASA doesn't allow me to do it---
ERROR: Cannot add route entry, conflict with existing routes
Can anyone kindly advise how to achieve it? TIA.
Overall Rating: 5 (1 ratings)
mkharban Tue, 11/03/2009 - 10:31
We have two ways of doing it. Below given are both the methods:
Terminating two ISPs on ASA/PIX-
ISP1------------------Internet
1.1.1.2 |
1.1.1.1 |
PIX/ASA|2.2.2.1----2.2.2.2|ISP2
3.3.3.1
Internal Network
Lets say we has above setup, with ISP1 being the Primary ISP
and ISP2 being the Secondary ISP.
I'm assuming that you all know how ISP failback is configured and
how it functions. To summarize, in ISP failback all traffic goes out
using ISP1 and if it fails, ASA/PIX starts routing traffic via ISP2.
Scenario I
Now, we do not want to configure ISP failback, but we needs
to route Web (port 80,443) traffic via ISP2 and all other traffic
via ISP1. This requires PBR, which is not supported on ASA/PIX, but
we can configure a workaround on ASA/PIX to make it work.
Following are the commands which will achieve it-
route ISP1 0 0 1.1.1.2 //Default route pointing to ISP1
route ISP2 0 0 2.2.2.2 2 //Default route with Metric 2 via ISP2
static (ISP2,inside) tcp 0.0.0.0 80 0.0.0.0 80
static (ISP2,inside) tcp 0.0.0.0 443 0.0.0.0 443
sysopt noproxyarp inside
nat (inside) 1 0 0
global (ISP1) 1 interface
global (ISP2) 1 interface
Thats it !! Now all the traffic destined to any address on port 80/443
will be forcibly put on ISP2 interface and routed from there.
Note: This stuff requires that we KNOW what the destination ports are,
if there is some traffic which uses dynamic ports, like voice traffic
we will have to route it via ISP1 and cannot make it route via ISP2.
Scenario II
In the same setup, if we say that we wants half traffic to go
via ISP1 and half traffic via ISP2, first we need to understand
that ASA is NOT a load-balancer or packet-shaper. Hence we cannot
*truly* achieve this, but we may configure ASA in such a manner that
traffic for some destination IP address is routed via ISP1 and some
is routed via ISP2. Following would be configuration commands in this
scenario-
nat (inside) 1 0 0
route ISP1 128.0.0.0 128.0.0.0 1.1.1.2
route ISP2 0.0.0.0 128.0.0.0 2.2.2.2
The first creates a default route that routes addresses with the first
bit of 1 to 1.1.1.2 of ISP1.
The second creates a default route that routes addresses with the first
bit of 0 to 2.2.2.2 of ISP2.
Note: This will do traffic routing based on *Destination* IP addresses and
NOT based on traffic load. As I mentioned, ASA is NOT a packet-shaper.
Hope this helps!
David Lin Tue, 11/03/2009 - 13:48
Thank you for your so detail explaination!
I tested method I and it worked fine. But some applications request dynamic detination port in both two networks, so I can use this way.
Regarding to the second solution, can both 2 networks be fully reachable from Internet if I sperate the route?
Thank you so much.
mkharban Tue, 11/03/2009 - 13:51
Yes,
Both the networks will be reachable from the internet if the routes are separated.
Hope this helps!
David Lin Wed, 11/04/2009 - 10:57
But I'm having difficulty to ping ISP2 from ISP1 network or vice versa.
I tried to ping them from ISP3, it's same.
no nameif
security-level 0
no ip address
vlan 10
nameif ISP1
security-level 0
ip address 1.1.1.2 255.255.255.0
vlan 20
nameif ISP2
security-level 0
ip address 2.2.2.2 255.255.255.0
nameif inside
security-level 100
route ISP1 0.0.0.0 0.0.0.0 1.1.1.1 1
route ISP2 128.0.0.0 255.0.0.0 1.1.1.2 1
