IPSEC VPN With DYNAMIC IP ADDRESS
Nov 3rd, 2009
i have ASA 8.0 with static ip address and remote site has a ADSL ROuter with dynamic IP address.
I am not able to make the Site to site vpn connection. I have tried dynamic map and standard site to site vpn
connection but nothing is working for me.
Please help me out. I am tottally stuck.I have attached the router and firewall configuration and below error I am getting.
Nov 3 18:08:34.606: IPSEC(key_engine): request timer fired: count = 1,
(identity) local= 83.110.195.120, remote= x.x.x.x,
local_proxy= 172.17.245.210/255.255.255.255/0/0 (type=1),
remote_proxy= 192.168.0.0/255.255.0.0/0/0 (type=4)
Nov 3 18:08:34.606: IPSEC(sa_request): ,
(key eng. msg.) OUTBOUND local= 83.110.195.120, remote= x.x.x.x,
remote_proxy= 192.168.0.0/255.255.0.0/0/0 (type=4),
protocol= ESP, transform= esp-3des esp-md5-hmac (Tunnel),
lifedur= 3600s and 4608000kb,
spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x0
RISTAR-JXB#
RISTAR-JXB#
Nov 3 18:08:34.810: IPSEC(key_engine): got a queue event with 1 KMI message(s)
If I give 0.0.0.0 in tunnel group configuraion it gave me following error.
ENOCDC-FW03(config)# tunnel-group 0.0.0.0 type ipsec-l2l
WARNING: L2L tunnel-groups that have names which are not an IP
address may only be used if the tunnel authentication
method is Digitial Certificates and/or The peer is
configured to use Aggressive Mode
I have change the rotuer configuration to aggressive mode but still no luck
acomiskey Tue, 11/03/2009 - 13:43
  • Green, 3000 points or more
You want to use the DefaultL2LGroup for your tunnel group name, not 0.0.0.0.
wasiimcisco Wed, 11/04/2009 - 07:39
Yes Right and i even tried this but still not working. I am getting following errors on router.
my head office firewall has mulitple site to site VPP connection and remote access vpn and it is working fine but only this VPN connection is giving me problem. I have tried all.
acomiskey Thu, 11/05/2009 - 05:56
First off, your crypto acl's should be mirrors of each other. This is how they are now...
Router
access-list 115 permit ip host 172.17.245.210 192.168.0.0 0.0.255.255
ASA
access-list TRJXB extended permit ip 192.168.0.0 255.255.0.0 172.17.245.0 255.255.255.0
This is what they should be...
Router
access-list 115 permit ip host 172.17.245.0 0.0.0.255 192.168.0.0 0.0.255.255
ASA
wasiimcisco Thu, 11/05/2009 - 07:08
On ASA firewall I am making dynamic map. like
Dynamic IPsec Between a Statically addressed PIX and a Dynamically addressed IOS Router with NAT Configuration Example
In dynanic map I dont have any option to recall the interesting traffic.
acomiskey Thu, 11/05/2009 - 07:12
Sure you do, it's right here...
crypto dynamic-map TRJXB_MAP 151 match address TRJXB
wasiimcisco Thu, 11/05/2009 - 07:53
I have configured this
crypto dynamic-map TRI_MAP 17 match address TRJXB
access-list TRJXB extended permit ip 192.168.0.0 255.255.0.0 17.1.1.0 255.255.255.0
access-list TRJXB extended permit ip 192.168.0.0 255.255.0.0 6.1.1.0 255.255.255.0
access-list TRJXB extended permit ip 16.1.1.0 255.255.255.0 6.1.1.0 255.255.255.0
access-list TRJXB extended permit ip 16.1.1.0 255.255.255.0 17.1.1.0 255.255.255.0
access-list TRJXB extended permit ip 16.1.1.0 255.255.255.0 172.17.245.0 255.255.255.0
access-list acl-nonat extended permit ip 16.1.1.0 255.255.255.0 host 6.1.1.1
access-list acl-nonat extended permit ip 192.168.0.0 255.255.0.0 host 6.1.1.1
access-list acl-nonat extended permit ip 16.1.1.0 255.255.255.0 17.1.1.0 255.255.255.0
access-list acl-nonat extended permit ip 16.1.1.0 255.255.255.0 host 172.17.245.7
access-list acl-nonat extended permit ip 16.1.1.0 255.255.255.0 host 172.17.245.150
access-list acl-nonat extended permit ip 192.168.0.0 255.255.0.0 host 172.17.245.150
access-list acl-nonat extended permit ip 192.168.0.0 255.255.0.0 host 172.17.245.7
acomiskey Thu, 11/05/2009 - 08:05
Those aren't exact mirrors of eachother and the crypto acl on your router isn't acl-nonat, it's acl 115.
acomiskey Thu, 11/05/2009 - 08:14
Can you get the log from the ASA?
wasiimcisco Thu, 11/05/2009 - 08:26
Please find attached. I am really thankful for your support and time that you are giving me to solving this issue.
acomiskey Thu, 11/05/2009 - 08:40
Try this on the ASA.
crypto dynamic-map TRJXB-MAP 151 set pfs
wasiimcisco Thu, 11/05/2009 - 13:49
Tried but still not working. Even reconfigure the complete router. This time configure with the Aggressive mode on the router.
