SNR / Mobility disable remotely
Nov 3rd, 2009
Anyone knows of a way for the end user to disable Mobility remotely?
This is on CUCM 7.1, I don't see that option in the /ccmuser
Thanks!
Overall Rating: 4 (1 ratings)
Jaime Valencia Tue, 11/03/2009 - 12:26
Methods for Enabling and Disabling Mobile Connect
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsmobmgr.html#wp1212169
The following methods are available for enabling and disabling the Mobile Connect feature. This list provides the methods available to the administrator and to end users.
•Mobile phone by using Mobile Voice Access (2 to enable, 3 to disable)
•Mobile phone by using Enterprise Feature Access (2 to enable, 3 to disable)
•Desktop phone by using the Mobility softkey
•Cisco Unified CM User Options windows
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
