Quick Link Aggregation on 3750 Question
mparella
I am looking to configure LACP on 3750 and wondering if there are any special considerations I should be aware of like minimum IOS level or something like that?
Will rate posts.
Thanks!
Jon Marshall
Michael
Any recent IOS should be fine. Have a look at the config guide to see the configuration restrictions/guidelines -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_se/configuration/guide/swethchl.html#wp1021783
Jon
Giuseppe Larosa
Hello Michael,
I haven't checked but I think that you have a 12.2(25)Sxy or better you should be fine.
some older IOS versions needed some more commands to define the lacp system-id and channel-protocol command in interface config, but lacp has been introduced some years ago.
>> 12.1(14)EA1
The active and passive keywords were added.
= lacp
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_se/command/reference/cli1.html#wp1860162
so you should be fine unless you IOS is older then 12.1(14)EA1
Hope to help
Giuseppe
Great information, guys. Thanks it looks pretty straight forward.
