Password reset
sunilgavaskar
I did a password reset to my UC-500 router and after that I am unable to connect to Configuration assistant. When I connect my PC to the ethernet port I am unable to get automatic IP. Tried to assign the ip 192.168.10.x but still unable to connect using the ip 192.168.10.1
Can anybody suggest how can I use Cisco Configuration assistant to manage UC-500
5 Replies 5
Steven Smith
Level 7
Level 7
Did you set the config-register back to 0x2102?
Can you post a running config?
Can you post a show ver?
Yes. I have set it back to 0x2102.
This is the config I have followed
Power on the router
send break signal
confreg 0x2142
reset
en
enable password xxxx
enable secret  xxxx
confreg 0x2102
end
write
after this when i reboot the router it asks for username  and password
what will be the username  and password ? I have tried giving the username cisco and password which I have set in the above steps.
Please suggest.
In middle forgot to mention copy start run
I would need to see the startup config to tell you what the username might be.  If you can post that I can help.
Other wise, you could copy the factory default config from the flash (if it is still there) to the startup config.  That will default it to the current settings.
If you don't want the default settings, you could do this...
Power on the router
send break signal
confreg 0x2142
reset
en
copy start run
enable secret  xxxx
username cisco priviledge 15 secret cisco
confreg 0x2102
end
wr
That should get you in with cisco/cisco.
This is the running-config
Current configuration : 1263 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
voice-card 0
no dspfarm
archive
log config
  hidekeys
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Integrated-Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Vlan1
no ip address
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
line con 0
no modem enable
line aux 0
line 2
line vty 0 4
login
webvpn cef
end
The sh version is
Nov  3 21:43:58.711: %SYS-5-CONFIG_I: Configured from console by console
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(11)XW6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 14-Feb-08 02:24 by prod_rel_team
ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System returned to ROM by reload at 03:12:03 BST Wed Nov 4 2009
System image file is "flash:uc500-advipservicesk9-mz.124-11.XW6"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco UC520-16U-4FXO-K9 (MPC8358) processor (revision 0x202) with 249856K/12288K bytes of memory.
Processor board ID FTX1220Y1KG
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
22 User Licenses
10 FastEthernet interfaces
2 terminal lines
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
