11-03-2009 02:49 PM - edited 02-21-2020 04:22 PM
Hi there,
I'm having a terrible time configuring a remote access VPN and was hoping someone could help. I want to be able to use the Microsoft client instead of the cisco client. I've attached the relevant parts of my config (I think I have it all) and an isakmp debug from one of my *many* attempts to connect. Can someone please help me out?
Thanks in advance,
Brandon
11-04-2009 01:48 AM
These seem to be the relevant debugs:
Nov 03 2009 15:23:43: %ASA-6-713905: Group = DefaultRAGroup, IP = x.x.x.x, No valid authentication type found for the tunnel group
Nov 03 2009 15:23:43: %ASA-7-713906: Group = DefaultRAGroup, IP = x.x.x.x, peer is not authenticated by xauth - drop connection.
Can you try this:
tunnel-group DefaultRAGroup ipsec-attributes
isakmp ikev1-user-authentication xauth
I know it seems wrong since the L2TP client does not do xauth, but the ASA is intelligent enough to suppress xauth when it detects L2TP.
11-04-2009 05:32 AM
Thanks for the response.
I changed the command to xauth and now I see this message in the debug:
Nov 04 2009 08:29:01: %ASA-7-713906: Group = DefaultRAGroup, IP = x.x.x.x, peer is not authenticated by xauth - drop connection.
Nov 04 2009 08:29:01: %ASA-3-713902: Group = DefaultRAGroup, IP = x.x.x.x, QM FSM error (P2 struct &0xd8e8a3b8, mess id 0x1)!
Nov 04 2009 08:29:01: %ASA-7-715065: Group = DefaultRAGroup, IP = x.x.x.x, IKE QM Responder FSM error history (struct &0xd8e8a3b8)
Nov 04 2009 08:29:01: %ASA-7-713906: Group = DefaultRAGroup, IP = x.x.x.x, sending delete/delete with reason message
Nov 04 2009 08:29:01: %ASA-3-713902: Group = DefaultRAGroup, IP = x.x.x.x, Removing peer from correlator table failed, no match!
11-04-2009 06:20 AM
Do you still have
isakmp ikev1-user-authentication (outside) none
If so, remove it (or change it to xauth as well) please.
If not, can you post the current config and the complete debugs please, including "debug crypto isakmp 10" and "debug crypto ipsec 10".
BTW which version of Pix/ASA is this?
11-04-2009 06:48 AM
02-19-2010 04:39 AM
in your config
no crypto isakmp nat-traversal
log file
Nov 04 2009 09:45:51: %ASA-7-713025: Group = DefaultRAGroup, IP = x.x.x.x, Received remote Proxy Host data in ID Payload: Address x.x.x.x, Protocol 17, Port 1701
check IP address
IP = x.x.x.x, and Address x.x.x.x
Nov 04 2009 09:45:51: %ASA-7-713906: Group = DefaultRAGroup, IP = x.x.x.x, peer is not authenticated by xauth - drop connection.
try
crypto isakmp nat-traversal 65535
