Warning message
Automating user creation for Unity Connection when sync'd with LDAP
Nov 3rd, 2009
Is it possible to automatically create users that sync with unity connection?
I have a unity connection 7.0 server that is sync'd with LDAP and i use a ldap filter so that only users with a specific attribute are sync'd. I can see the users when i try to do an import but is there anyway that they can automatically be created
Overall Rating: 4 (1 ratings)
Jaime Valencia Tue, 11/03/2009 - 17:26
  • Cisco Employee,
  • Hall of Fame,
    2011
No
Check this check box so that Cisco Unity Connection gets basic information on Connection users from the LDAP directories that you specify on the LDAP Directory page. Data is synchronized only for the Connection users that you created by importing users from the LDAP directory. Connection does not automatically create new Connection users when new users are added to the LDAP directory.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/gui_reference/guide/7xcucgrg100.html#wp1069724
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
zane.england Wed, 11/04/2009 - 21:57
thought that was the case - thanks
guess i will have to use CUPI
John Gowen Sat, 03/27/2010 - 12:10
Hello Zane, I'm actually trying to create an LDAP filter to only import users with a specific attribute, but i'm having trouble.
could you let me know how you did it?
thanks in advance,
John
