ASA 8.2(1) /+CISCOA+/enroll.html authentication failed
Nov 4th, 2009
I'm trying to setup a LOCAL CA SERVER
for an ASA 5520.
i'm stoppped to the authentification page
/+CISCOA+/enroll.html from IE7
the server return authentication failed
even if i use the correct user One-time Password received by mail
Does anyone could help me ?
Overall Rating: 3 (1 ratings)
vchepikov Wed, 11/11/2009 - 04:46
if you do 'debug http 255', you'll see something like that:
HTTP: file not found: CSCOCA /enroll.html
Jagdeep Gambhir Wed, 11/11/2009 - 10:30
Not sure if you are accessing CA server or ASDM?
One time password does not work for http connection.
vchepikov Wed, 11/11/2009 - 12:18
He is accessing CA server running locally on ASA in order to enroll. But he couldn't get authenticated against CA user database (LOCAL AAA method is used instead). That's why OTP doesn't work for him.
vpancisco Thu, 11/12/2009 - 03:01
Thanks for interest
So i can't get authenticated against CA user database because LOCAL AAA method is used instead
How to set auth against CA user database ??
vpancisco Mon, 11/16/2009 - 02:17
thanks for all
i succed to enroll
the way is enable webvpn so as to
query the correct data-base
