Limit traffic on a gigabit/optical port
Nov 4th, 2009
We are facing the following problem. We have a gigabit/optical port on which we want to limit traffic. The port is configured as switchport. The only option about speed is "speed nonenegotiate". What can be a work around to this problem?
Thanks in advance,
katerina.dardoufa Fri, 11/06/2009 - 02:49
Thank you all for your interesting links. I will have a look and hopefully find the solution. The thing is that since the switch is very critical and it's difficult to reload, upgrading the IOS is out of the question. So I have I find a solution in the links.
