Antenna connector wap200G
Glenn Quesenberry Fri, 11/06/2009 - 13:29
The WAP200 uses an SMA type of antenna while as you state the HGA9N antenna is an "N" type.  You may be able to procure an adapter through a 3rd Party company like "L-Com" or others, however we cannot guarantee your sucess or performance in this type of configuration.  I would recommend you acquire an SMA type of antenna instead.  These would also be available through a 3rd Party.
Best Regards,
