OSPF neighbors on 2800
Nov 4th, 2009
i have about 900 router connected to two service provider with the Data center using L2 MPLS ATOM. i need to know the 2800 capability with about 900 neighbor and 4000 routes. if it works fine how can i tune the network to get high speed convergence and minimize the routing update.
Giuseppe Larosa Wed, 11/04/2009 - 06:11
Hello Mohamed,
I would be satisfied to have a C2800 that has 900 neighbors and 4000 routes!
have you been able to have 900 neighbors on it, who is the DR?
be aware that any tuning would imply a greater use of cpu resources.
For example using sub-second hello timers with 900 neighbors is a problem.
Hope to help
mohamed.taher Wed, 11/04/2009 - 06:26
Hi Giuseppe
i do not implement it now but i compare between the RIP and OSPF. if you have any document related to ospf and 2800 please send it to me as i think it will cause high CPU and Memory utilization.
