Warning message
"Disable account if failed attempts exceed x on" group object
Answered Question
Nov 4th, 2009
When setting up a group in ACS 4.1, how do you include the "disable account if failed attempts exceed x" on the Group object. I see there have been some topics on this for older ACS versions (3.x) where it was not possible. Just wondering if anyone knows if this is possible on ACS 4.1 or possibly 4.2?
Correct Answer by Jatin Katyal about 7 years 9 months ago
In newer version also 4.x, this can only be set on only user setup.
Can't set this on group level.
JK
-plz rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
Jatin Katyal Wed, 11/04/2009 - 06:39
  • Cisco Employee,
JK
