com.cisco.app.Application Task inactive Exception
Anthony Holloway Wed, 11/04/2009 - 06:58
  • Purple, 4500 points or more
Are you using the On Exception Goto Step to catch Inactive Contacts and ending the script cleanly, instead of letting it fail?
Also, are you using a 2 second delay before the Accept step to allow CUCM and UCCX to complete the call setup?
christfoster Mon, 11/16/2009 - 17:35
Where should the the exception task goto step be place? We are experiencing these errors withing all our queues...
Jonathan Schulenberg Mon, 11/16/2009 - 17:55
  • Cisco Designated VIP,
    2017 IP Telephony
Example:
On Exception Goto (ContactInactiveException) Goto END
Accept
...rest of script...
Disconnect [Label: DISCONNECT_END]
End [Label: END]
Note that callers will (and should) show as abandoned if this exception is caught. You might want to review my answer to another post if you want to control this at a more granular level:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Contact%20Center&topicID=.ee6fe12&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd4ae2b
christfoster Mon, 11/16/2009 - 19:26
com.cisco.app.ApplicationTaskInactiveException
What does this error mean ?
After restarting my UCCX we have been receiving over 200 abandon calls with this error..
jawilson_1 Fri, 08/16/2013 - 12:56
Jonathan, I can't find your post anywhere.  Do you still have it after all this time?
Mustapha Arakji Sun, 10/16/2011 - 15:19
Hi Guys,
Still looking for an answer regarding this message. I'm checking my UCCX reports and i can see a significant number of Aborted calls with reason code: com.cisco.app.ApplicationTaskInactiveException. I can't understand why, though i have debuged the script and couldn't find an error in the script.
Also I'm using the Exception Goto setp and ending the script successfully. In my report i can see the call is sent to a CSQ, then get aborted !! If the caller hangs up shouldn't the report show as abandoned !?
