IP Phones and Routing
Nov 4th, 2009
Dears,
is it possible to connect IP phones over 2 routed sites (L3 2 connected sites throughou routers ) instead of switched ones ( connected thru switches L2 trunked )
if possible, what conig. should be added to the router or the 2 switches on both sides?
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 11/04/2009 - 07:03
  • Hall of Fame,
    Founding Member
Of course it is possible.
Are you the end-user or do you own any certification or equivalent networking experience ?
paolo bevilacqua Wed, 11/04/2009 - 07:36
  • Hall of Fame,
    Founding Member
VoIP is not anything special. All normal routing rules apply.
