SA 520 L2L VPN
I have two SA520's and setup a VPN between the two.  The tunnel is up and I can see both are transmitting data, but can't see if the other end is receiving.  The ipsec status only has transmit stats.  I also can't ping across the tunnel to hosts.
Is there something I miss where I need to put in a NAT exemption or something?
Is there a status page that has Tx AND Rx, not just Tx?
jamccord Wed, 11/04/2009 - 11:11
Matt,
What are you trying to ping on the remote network?  Does that device have a firewall?  If so, please disable the firewall.
Can you ping the remote gateway?
Jason
jamccord Thu, 11/05/2009 - 05:52
Thanks for posting that your problem has been resolved, as well as the solution.
Jason
