Mixed MCS Cluster
Answered Question
Nov 4th, 2009
  • Silver, 250 points or more
Can, has anyone installed a cluster with mixed MCS server 7835 and 7845 etc. We are looking at this arrangement to increase the CTI connections which the 7845 will give us. Does replication became an issue due to the difference size of server, if you also use the 67845 for CTI , TFTP, MOH is replication an issue still?
thanks
Correct Answer by kelvin.blair about 7 years 7 months ago
As Rob stated, yes it is possible to mix and match, but only with 7825's and up. This is documented in the CUCM 7.0 SRND.
Correct Answer by Rob Huffman about 7 years 7 months ago
Hi IPT,
We have sucessfully used a cluster built with a mix of 7835's and 7845's without any replications issues. If you use a ton of MOH resources a separate MOH server is recommended :)
Cheers!
Rob
Overall Rating: 5 (4 ratings)
Correct Answer
Rob Huffman Wed, 11/04/2009 - 11:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi IPT,
Cheers!
Rob
Correct Answer
kelvin.blair Wed, 11/04/2009 - 12:34
