Cisco Call Manage as a DHCP Server- IP Phones are not registered.
HI,
I have two site , site 1 and site 2. both the sites are interconnected via MPLS .both the sites are using the same IP Address range... 192.168.1.x and I have only one Call Manager for both the sites (which is a DHCP Server for both sites). IP Phones are facing conflicting problem via IP assingment. Please find the attached file for refference.
Please suggest the best way out to solve this issue.
Manish.
Abdulbaseer Mohammed Thu, 11/05/2009 - 07:20
Hi Manish,
You may get quicker and better response if you post this under IP telephony or ip phone service.
I am least knowledgeable on these DHCP issues but should they not have different IP's? especially if they have one same DHCP server.
Good luck.
Baseer.
