ASA 5510 remote access VPN clients are prompted to authenticate to box
Answered Question
Not sure what the deal is but my remote access users are being prompted to login to the ASA before connecting to tunnel. How can I disable this? Attached is config. Thanks all-
Correct Answer by hdashnau about 7 years 3 months ago
For remote access connections you can disable the xauth (user/pass) prompt with the following:
tunnel-group ipsec-attributes
isakmp ikev1-user-authentication none
-heather
Overall Rating: 5 (1 ratings)
Yudong Wu Wed, 11/04/2009 - 23:33
can you try to use "no" command to remove the following two config?
secure-unit-authentication disable
user-authentication disable
Yudong Wu Thu, 11/05/2009 - 09:24
Do the remote users use Cisco VPN client software? Or they tried to use WebVPN?
Can you show us what authentication prompt you got?
Correct Answer
hdashnau Thu, 11/05/2009 - 09:32
-heather
