can not ping aim-cue
Nov 4th, 2009
Any idea why I cannot ping the AIM-CUE ?
thanks
interface Service-Engine0/0
ip address 10.224.32.17 255.255.255.252
service-module ip address 10.224.32.18 255.255.255.252
service-module ip default-gateway 10.224.32.17
#ping 10.224.32.18
Sending 5, 100-byte ICMP Echos to 10.224.32.18, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Paolo Bevilacqua Wed, 11/04/2009 - 13:33
  • Hall of Fame,
    Founding Member
Check that module is running, via service-module session.
blackswans Wed, 11/04/2009 - 22:46
I can make session to module, and also it says up when I check it.
Paolo Bevilacqua Thu, 11/05/2009 - 02:06
  • Hall of Fame,
    Founding Member
When is session, check with the show commands, thta the addresses are right.
Hythim Ali El Hadad Thu, 11/05/2009 - 02:33
  • Silver, 250 points or more
Check to have an ip route to the service module ip address with subnet /32 and output interface service engine
thanks & best Regards
Hytham Hadad
Paolo Bevilacqua Thu, 11/05/2009 - 02:37
  • Hall of Fame,
    Founding Member
That should not be necessary, because a dedicated subnet is being used, not unnumbered.
However, I agree that unnumbered using a voice VLAN address is a better choice.
blackswans Thu, 11/05/2009 - 03:19
I reloaded the module and it is ok now :) interesting...
Paolo Bevilacqua Thu, 11/05/2009 - 03:35
  • Hall of Fame,
    Founding Member
Why you should ?
Either use explicit or unnmbered, as recommended by configuration guides.
Paolo Bevilacqua Sat, 11/07/2009 - 10:49
  • Hall of Fame,
    Founding Member
You are welcome, please remember to rate useful posts with the scrollbox below.
