Checking for recorded greeting
Answered Question
Nov 4th, 2009
Does anyone know of a way to pull a report on mailboxes that will tell whether or not the mailbox has been set up?
Correct Answer by Christopher McAlpin about 7 years 6 months ago
Yes, in the Tools Depot under Administration Tools there is a utility called Subscriber Information Dump. This utility allow folks to quickly dump out specific information about the subscribers in their system to a file they can view or import into another application such as a database utility or Excel or whatever. You would probably be intrested in the "Set for First Time Enrollment" field.
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 11/04/2009 - 17:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Bernece,
There is a perfect tool for this type of report. We have used this during our rollout to search for the same info.
**I don't believe any of the "built-in" CUC Reports will show this info :)
Check the "Set for First Time Enrollment" and "Voice name Recorded";
Connection User Data Dump (CUDD) Tool
The Connection User Data Dump (CUDD) is a Windows-based remote database administration tool available on the Cisco Unity Tools website. CUDD allows you to export specific information about users to a file that can be viewed or imported into another application, such as a database utility or Microsoft Excel. When the data is exported, the tool automatically creates a header row that lists the data type found in each column of the output, for ease of import into other programs.
The tool is available from the "Superb" Unity Tools site;
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
From the Help Notes;
Requirements/Special Notes
This version of User Data Dump runs on Windows XP/2000/2003 or Vista.
***This version of User Data Dump only works with Unity Connection 7.0(1) or later.
Hope this helps!
Rob
Correct Answer
Christopher McAlpin Wed, 11/04/2009 - 18:51
  • Cisco Employee,
Mybabesx2 Thu, 11/05/2009 - 06:08
Thank you. That was exactly what I was looking for.
