Phone reset after xml service request on CUCM 7.0
Nov 4th, 2009
Hi I'm configuring an XML service on CUCM 7.0. But when the service is requested from an IP phone 7942-62 or 7975 the phone try to request the service an immediatly go to reset.
I already have a server with IIS instaleed an is where the xml. I try with applications of the SDK and the result is the same.
Do you have any idea of this.
Thanks.
da.rivera Mon, 11/09/2009 - 09:34
Hi every body, I solved the problem. In really it was a mistake in the path of the service.
regards.
