SPA941 Deployment and Provisioning
Nov 4th, 2009
I have a 50+ phone system using SPA941 phones. I have manually configured each phone and we are getting ready to launch more. I have successfully created an auto-provision master cfg file (spa941.cfg) and a phone specific cfg file (spa000e08d2ca16.cfg) - which in a test environment, utilizing TFTP downloaded and installed the provision settings correctly. I also indicated that the firware autoupdates from version 4.x (Sipura) to Cisco spa941-5-1-8.bin. I have also caught the DHCP OFFER packet in which I am using dhcp-option:66,"ip-address" - which is coming correctly thru (ironically on the bootp "server name" param). After updating the firmware - the phone has stopped auto-provissioning and will not retrieve the ftp server name (Profile Rule). I have done factory resets, hard boots, soft boots - you name it. I may have answered my own question, but has anyone ever encountered this? I may rollback to the original firmware...
Help!
UPDATE:
I have reverted back to the sipura spa941-4-1-15.bin image with no luck.  I seems that the Profile Rule (for the ftp server address) is not pulling down correctly.  Now - I am using a Linksys WRT54GL router flashed with Tomato (stripped down OpenWRT) that has dhcp-option 66 configured as an additional param in the dnsmasq service.  Using wireshark I inspected again and observed that the phone will not pick up the server name.
THE ONLY THING is that I don't see and explicit OPTION=66 in the DHCP Offer packet - is this correct?  The ftp server is in the  bootp "server name" param - and that worked the original time I took the phone out of the box.
ChrisCogdon Fri, 11/27/2009 - 22:40
This might be really silly, or the solution... i didn't think the phones could do FTP. Your choices were TFTP or HTTP. If that was a mistake, then you need to change the server name to "tftp://example.com" rather than "ftp://example.com"
shawnbure Tue, 02/23/2010 - 13:33
For anyone that wants to know - both posts helped.  The last post was correct - the Linksys SPA941 does not do ftp even though it says it does - only tftp and http!
shawnbure Sun, 07/18/2010 - 13:23
For tomato users - the option dhcp-options-force=66,192.168.x.x will make the DHCP Option 66 come through the actual DHCP options.  If you use dhcp-options=66,192.168.x.x it will only come through the bootp otions.
Patrick Born Tue, 11/10/2009 - 17:09
Hi shawnbure,
This is correct, bootp is the ancestor of DHCP this is why you filter with bootp in WireShark when filtering for DHCP. :-)
I'm guessing that the DHCP server is not appropriately configured to supply the TFTP server's IP address. No two DHCP servers are the same. Here's what my /etc/dhcp/dhcpd.conf looks like:
subnet 192.168.2.0 netmask 255.255.255.0 {
authoritative;
interface eth0;
range 192.168.2.155 192.168.2.180;
default-lease-time 1800;
max-lease-time 7200;
option subnet-mask 255.255.255.0;
option broadcast-address 192.168.2.255;
option routers 192.168.2.254;
option domain-name-servers 24.93.41.125, 24.93.41.126;
option tftp-server-name "192.168.2.245";
option ntp-servers pool.ntp.org;
This is what you should see [Click image to view bigger]:
Take a look at this document that shows the entire trace of the boot sequence in the back-matter: https://supportforums.cisco.com/docs/DOC-9954
Patrick
