Configuring SSL VPN on ASA5520
Herbert Baerten Wed, 11/04/2009 - 23:40
  • Cisco Employee,
Well we'll need a bit more information to be able to help :)
What did you try exactly? Can you share your config please?
And how is it not working precisely? What happens (step by step) when you try to connect?
What do the syslogs show?
I took off the entire SSL VPN configuration after it did not work. I need design guidance to implement the solution for over 500 plus users. Currently remote users are using ipsec tunnel with anyconnect. I don't think posting my config will show you anything regarding SSL VPN.
So my question is what would be my starting point to move over to SSL VPN.
