ntp sync on IPS
Nov 5th, 2009
I have a bunch of IPS which are not synced anymore with the ntp server( Core switch) sicne the time on that core switch has been modified.
I there a way to force ntp sync on the IPS without having to reload the IPS
andrey.dugin Thu, 11/05/2009 - 04:39
According to my experience if you set the ntp from IME you must restart the sensor but if you do it via CLI sensor will not be restarted.
In any case you may try it and check does the configuration via CLI require reboot.
Post your result here.
k.abillama Thu, 11/05/2009 - 22:21
I will try it via command line and post the result, thx for the hint
