route leakage
Giuseppe Larosa Fri, 11/06/2009 - 00:43
Hello Ola,
look if there is a vrf option in the command that specifies the source for SNMP traps
http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_20.html#wp1024558
unfortunately I don't see this vrf option in command
snmp-server source interface as it happens in other commands
so actually a route leakage approach is needed in your case.
one way could be the following:
associate an ip subnet both to the VRF and to the GRT.
vlans X and Y connect with a crossover cable one access-port in vlan X with one port in vlan Y.
and
ip route trap-server 255.255.255.255 vlanX
snmp-server source interface vlan X
Hope to help
Giuseppe
