11-05-2009 01:59 AM - edited 03-06-2019 08:27 AM
Hi All,
I suddenly noticed that my one of the IOS-Firewall where all NAT configuration done.
When I verified the log I found below logs....
Router uptime is 33 minutes
System returned to ROM by error - an unknown failure, PC 0x6025C7E4 at 09:37:05 UTC Thu Nov 5 2009
Alignment correction made at 0x602932D0 reading 0xEE9F850E
Nov 5 07:36:22.975: %ALIGN-3-TRACE: -Traceback= 0x602932D0 0x60295EA0 0x600479E4 0x6002A19C 0x62A25574 0x62A2C9A0 0x62A29180
0x62A293FC
Nov 5 07:36:22.979: %ALIGN-3-CORRECT: Alignment correction made at 0x602932D0 reading 0xEEA5A38E
Nov 5 07:36:22.979: %ALIGN-3-TRACE: -Traceback= 0x602932D0 0x60295EA0 0x600479E4 0x6002A19C 0x62A25574 0x62A2C9A0 0x62A29180
0x62A29424
Experts can some one please tell me what is this error came and how it caused to my router reboot.
And please help me to avoid this kind of interrupts in future and what precautions I need to take care as it is core router for my whole organization.
Naidu.
11-05-2009 04:04 AM
Normally indicates a software defect. See http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_tech_note09186a00800a65d1.shtml#align
Bug tool might have it documented. If it does, believe it would note whether it's been fixed or whether there's a work around. Otherwise, you'll need to open a TAC case or perhaps try a different IOS version.
11-05-2009 04:30 AM
Hi Joseph,
Thanks for your response.
I saw the same site before created this post.
But unfortunately I could not understand what it mean...
Cause
Alignment errors are caused by misaligned reads and writes. For example, a two byte read where the memory address is not an even multiple of two bytes is an alignment error. Alignment errors are caused by a software bug.
Correcting Alignment Errors
Alignment errors can generally be corrected by software and, if so, will not cause a crash. Correcting alignment errors does, however, consume processor resources and can result in a performance penalty. If there are continuous alignment errors, the router can spend most of its time fixing them, increasing the CPU utilization. These errors are corrected at interrupt.
My router showing at first line in show version like...
What could be the cause for this...
Naidu.
11-05-2009 04:41 AM
"But unfortunately I could not understand what it mean..."
It means, whatever you're doing with this router might have found a "software defect" (i.e. bug).
These shouldn't normally happen. Often the solution is found in moving to a different IOS code version (often newer, sometimes older). If you have a service contract, you would also work with Cisco TAC.
11-05-2009 04:57 AM
Hi Joseph,
The router have new version. Please find the below show version details.
Unfortunately I have not cisco contract....I am at strange what to do to not repeat in future.
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 12.4(11)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 18-Nov-06 15:32 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
DKIGNFW01 uptime is 5 hours, 24 minutes
System restarted at 09:34:10 UTC Thu Nov 5 2009
System image file is "flash:c1841-adventerprisek9-mz.124-11.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 1841 (revision 6.0) with 236544K/25600K bytes of memory.
Processor board ID FCZ1037221E
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Thanks in advance.
Naidu.
11-05-2009 05:28 AM
"The router have new version."
Actually it has a "newer" 12.4T release, but I just looked and didn't see any 12.4(11)T releases except 12.4(11)T1..4 under "Deferred Releases" (which normally indicates bugs so bad they've been pulled from distribution).
"Unfortunately I have not cisco contract."
That makes things more difficult. Since it appears most, if not all, of the 12.4(11)T series for an 1841 are "deferred", Cisco might provide you another release if you contact them. I believe it might also be possible to purchase another IOS image, but I'm unsure. Perhaps someone more familar with software licensing might comment.
