Restricting Internet Access
Nov 5th, 2009
Does anyone know if there is a stand-alone way on a Cisco router to prompt a user for a password when trying to get Internet access? There would be no other authentication method or devices other than having to enter a password. If thre was a way to present this pssword prompt as a web page that would be fantastic.
Thanks in advance! All replies rated!
Overall Rating: 5 (3 ratings)
angel-moon Fri, 11/06/2009 - 06:45
Thanks Guys. Do either of you, or anyone else know if the authentication proxy HTML login page that users get can be customized?
Jagdeep Gambhir Fri, 11/06/2009 - 09:17
Hi Angel,
As per my understanding auth-proxy authentication page can not be customizable
When auth-proxy is enable and the user is prompted for authentication. You can use the current available banner command to enter some text.
Do rate helpful posts
