How to take backup of ios to pc running federo core 2 os
Nov 5th, 2009
This is munihar.In my lab we are using federo core 2 and 5 version os.we have tftpd software for backup.
But we dont know how to install and use it correctly.actually we installed this tftpd s/w in /opt folder but still we couldn't access.
any one can help me in this issue....
Thanks for reading..
mmacdonald70 Sun, 11/08/2009 - 07:06
This is probably better directed at a Fedora community but some basic things to check:
- If there a firewall on the Fedora Box?
- most tftp servers will not allow you to create files in with tftp. You would need to create the file first
- Can you use SCP (copy startup-config scp:
scottmac Mon, 11/09/2009 - 18:29
Tftp is a native application for those distributions.
You should be able to enable them in the services admin tab. There is also likely a ftpd.conf file in /etc or a subdirectory below /etc, where you configure the target directory, access, and the rest of the details.
