11-05-2009 07:49 AM
I'm trying to set up two ace 4170 in HA configuration.
Currently one of the devices is doing ssl offload and load balancing and is working fine.
What has to be done on the new unit in order for them to work as a HA pair?
Attached is my current config (I added HA setting in the unit allready).
Thank you.
Solved! Go to Solution.
11-05-2009 11:36 AM
You simply need to configure ft related command on Standby and standby ACE will copy the config over from primary.
Assuming you are only using Admin context following will be the config on Primary & Standby ACE
------ on Primary ------
interface gigabitEthernet 1/2
ft-port vlan 30
no shutdown
ft interface vlan 30
ip address 192.168.60.1 255.255.255.0
peer ip address 192.168.60.2 255.255.255.0
no shutdown
ft peer 1
heartbeat interval 300
heartbeat count 10
ft-interface vlan 30
ft group 1
peer 1
priority 200
peer priority 100
associate-context Admin
inservice
-------------- On Secondary ---------------
ft-port vlan 30
no shutdown
peer ip address 192.168.60.1 255.255.255.0
no shutdown
ft peer 1
heartbeat count 10
ft group 1
peer 1
priority 100
peer priority 200
inservice
Syed Iftekhar Ahmed
11-05-2009 11:36 AM
ft-port vlan 30
no shutdown
no shutdown
ft peer 1
heartbeat count 10
ft group 1
peer 1
priority 200
peer priority 100
inservice
ft-port vlan 30
no shutdown
no shutdown
ft peer 1
heartbeat count 10
ft group 1
peer 1
priority 100
peer priority 200
inservice
Syed Iftekhar Ahmed
11-06-2009 06:15 AM
Thank you very much Syed!
I managed to get them working in failover.
