Cisco 7600 VLAN based QoS
Nov 5th, 2009
I have Cisco 7600 router, switching traffic between two physical port and SVI interface for example.
Both physical ports in 'mls qos vlan-based' state.
Next I configured acl, class-map and policy-map:
ip access-list standard ACL_test
permit any
class-map match-all CM_test
match access-group name ACL_test
policy-map PM_test
class CM_test
police rate 70000000 bps
and applied it to VLAN SVI interface:
interface Vlan3
ip address
no ip proxy-arp
service-policy input PM_test
service-policy output PM_test
Accordingly to attached image, what input and output traffic flows will be limited to 70 Mbps?
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 11/06/2009 - 01:37
Hello Miksim,
>>With a PFC2, PFC QoS does not support VLAN-based QoS with DFCs installed.
•With a PFC3, PFC QoS supports VLAN-based QoS with DFC3s installed.
•With a PFC3, you can attach policy maps to Layer 3 interfaces for application of PFC QoS to egress traffic. VLAN-based or port-based PFC QoS on Layer 2 ports is not relevant to application of PFC QoS to egress traffic on Layer 3 interfaces.
my understanding is the following:
the sum of traffic rates exiting the SVI to other IP subnets is that of the rate.
policing inbound applies to the physical ports so sum of inbound rates on ports is limited to the rate value.
as a result of this hosts in vlan3 cannot transfer more then 70 Mbps to other IP subnets/Vlans.
Hope to help
mkachalin Fri, 11/06/2009 - 02:43
Hello Giuseppe.
Thanks for an useful anwer!
Will wait in this topic for somebody else, who used this future in production environment.
