Technical difference between power cycle vs. reboot
Answered Question
Nov 5th, 2009
Folks, if you remove power cable from a device, then connect power cable back in that is a power cycle.
Then from a Cisco switch if you issue the 'reload' command, the device would "reboot".
Question:As far as getting memory cleared, do you see any difference between the two? I heard in the past that some devices may not get the memory cleared unless you power cycle (what it does not make sense to me, but I just want to confirm).
Correct Answer by Lucien Avramov about 7 years 3 months ago
Reboot from CLI is more clean than a brutal power cycle.
If you do a warm reboot, then it will not clean all the memory as the warm reboot is made to restart the router in a few seconds.
To answer your question, a reboot should have the same effect as a power cycle as far as memory clearing.
Overall Rating: 5 (1 ratings)
Correct Answer
Lucien Avramov Thu, 11/05/2009 - 10:28
