AAA Users and Passwords
Answered Question
Nov 5th, 2009
Hi All,
I'm currently studying for my CCNA Security and have been toying around with AAA. I have an 851w with advsecurity 12.4 IOS.
What I have noticed, and find interesting is that I seem to have one user configured locally, but it appears to have two passwords.
For instance, if I log in with SSH or telnet, I enter my username with password 'ABC' and I'm in. This account is privilege level 15. However, if I access the SDM, I must enter the same username with a different password, e.g. '1234'. If I enter the password 'ABC' which works for SSH and telnet, I am not granted access.
I was wondering if anyone can explain this? I have tried using the show aaa commands to see what is going on, but it doesn't seem to help. As I said, aaa is using the local database for its user database. Below is some config.
Any help greatly appreciated.
Cheers,
Conor
aaa new-model
aaa authentication login default local
aaa authentication login NO_LOGIN none
aaa authorization exec default local
aaa session-id common
username conor privilege 15 secret 5 blahblah
line con 0
exec-timeout 300 0
privilege level 15
password 7 blahblah
logging synchronous
login authentication NO_LOGIN
no modem enable
line aux 0
line vty 0 4
exec-timeout 300 0
privilege level 15
password 7 blahblah
logging synchronous
Correct Answer by Jatin Katyal about 7 years 7 months ago
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Thu, 11/05/2009 - 10:32
  • Red, 2250 points or more
Please get the debugs for both instances, telnet and SDM
debug aaa authentication
debug aaa authorization
~JG
Conor Cunningham Thu, 11/05/2009 - 11:25
Hi JG,
Below is the output from the three various methods of logging in.
SSH
002578: Nov 5 19:37:14.744 PCTime: AAA/BIND(00000305): Bind i/f
002579: Nov 5 19:37:14.744 PCTime: AAA/AUTHEN/LOGIN (00000305): Pick method list 'default'
EDGE#
002580: Nov 5 19:37:17.652 PCTime: AAA/AUTHOR (0x305): Pick method list 'default'
002581: Nov 5 19:37:17.652 PCTime: AAA/AUTHOR/EXEC(00000305): processing AV cmd=
002582: Nov 5 19:37:17.652 PCTime: AAA/AUTHOR/EXEC(00000305): processing AV priv-lvl=15
002583: Nov 5 19:37:17.652 PCTime: AAA/AUTHOR/EXEC(00000305): Authorization successful
Telnet
002638: Nov 5 19:44:04.116 PCTime: AAA/BIND(0000033A): Bind i/f
002639: Nov 5 19:44:04.116 PCTime: AAA/AUTHEN/LOGIN (0000033A): Pick method list 'default'
EDGE#
002640: Nov 5 19:44:07.548 PCTime: AAA/AUTHOR (0x33A): Pick method list 'default'
002641: Nov 5 19:44:07.548 PCTime: AAA/AUTHOR/EXEC(0000033A): processing AV cmd=
002642: Nov 5 19:44:07.548 PCTime: AAA/AUTHOR/EXEC(0000033A): processing AV priv-lvl=15
002643: Nov 5 19:44:07.548 PCTime: AAA/AUTHOR/EXEC(0000033A): Authorization successful
SDM via HTTPS
002647: Nov 5 19:46:22.368 PCTime: AAA/BIND(0000033E): Bind i/f
002648: Nov 5 19:46:23.092 PCTime: AAA/BIND(0000033F): Bind i/f
These messages regarding SDM were repeated around 25 times.
Both Authorisation and Authentication debugging modes were on.
Thanks for the help. Much appreciated.
Conor
Conor Cunningham Thu, 11/05/2009 - 12:10
All,
I have worked out that the SDM is using my enable secret for authentication as opposed to AAA.
I assume this is the default behaviour. Thanks JG for getting me thinking along these lines by looking at the debug aaa authenication and authorisation.
If you know whether it is possible to configure SDM to authenticate against SDM, I would be more than happy to know how to perform such a configuration. I'm searching for such a config on google but not having much luck.
Again, thanks for pointing me in the right direction.
Cheers,
Conor
