Our main number 2500 vm box?
Answered Question
Nov 5th, 2009
Our receptionist can't login into the main # 2500 vm box?
I don't see a subscriber for 2500.
Can someone point me in the right direction?
CUCM BE 6.1
Correct Answer by Rob Huffman about 7 years 7 months ago
Hi Matt,
If this is a "Main" number, I would look for it a a Call Handler perhaps :)
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 11/05/2009 - 09:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Matt,
Cheers!
Rob
mattsmith@eurof... Thu, 11/05/2009 - 10:01
Rob,
Yes it is a Call Handler...
Opening Greeting #2500
What does this mean? is there a voice mailbox?
Matt
Rob Huffman Thu, 11/05/2009 - 11:08
  • Hall of Fame,
    Founding Member
Hi Matt,
A Call Handler can take a message and be associated with a Mailbox via "user with mailbox" under the Message setting section of the Call Handler setup. What are you trying to change/find??
Cheers!
Rob
mattsmith@eurof... Thu, 11/05/2009 - 11:19
Rob,
Our receptionist is trying to login into the mailbox when messages are left when she is away from the desk.
She told me the old phone admin reset the user account passwd! - I do not know what account she is speaking about.
Matt
Rob Huffman Thu, 11/05/2009 - 11:24
  • Hall of Fame,
    Founding Member
Hi Matt,
OK, this makes sense :) You need to reset the PIN that is associated to the Extension/DN that the admin is using on her phone.
Cheers!
Rob
Tommer Catlin Thu, 11/05/2009 - 11:53
  • Green, 3000 points or more
Go to the phone where she is, and ask her to dial the vicemail box. She must know the mailbox number or the line it came from.
Then trace it backwards in CUCM. From the phone she is on has a vm profile (default or maybe a different profile)
Then go to VM Profile and see if there is a VM Mask.
Note the mask or if no mask, its the same number from the line on the phone.
Go to Unity and search for this.
