Traffic management on 1760 router
Answered Question
Nov 5th, 2009
Hi, we have two internet connections at a remote site. The primary connection is a full T1 and DSL as a backup.
Is there a way to manage the router traffic to designate the DSL backup to handle all HTTP traffic and designate the T1 for all other traffic?
I ask because the DSL connection has a larger downstream speed.
Thank you,
Andrew
Correct Answer by JORGE RODRIGUEZ about 7 years 4 months ago
Andrew,
You will need to cofigure policy base routing on the 1760, you can have something as this.
route-map http-https_traffic_Via_DSL permit 10
description web outbound traffic_Via DSL
match ip address 101
set ip next-hop
access-list 101 permit tcp any any eq 80
access-list 101 permit tcp any any eq 443
Apply route map to router FEthernet interface
interface
ip policy route-map http-https_traffic_Via_DSL
any www and https traffic request coming from your LAN will go out via DSL link, none web traffic ftp rdp etc..will go regular default route via T1.
Hope this helps
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Thu, 11/05/2009 - 20:42
  • Green, 3000 points or more
Andrew,
set ip next-hop
interface
Hope this helps
JORGE RODRIGUEZ Sat, 11/07/2009 - 06:21
Andrew, are you all set with your request or still need help?
