Crypto Key Script will not work in config, but will manually
Nov 5th, 2009
y remote site customer has 3560 with 12.2(44)SE6, that if they run the command:
conf net
for a script:
crypto key generate rsa general-keys modulus 1024
It said it is successful, however, the configuration is not applied.
JSTA-MDF-s02#sh ip ssh
SSH Disabled - version 1.99
%Please create RSA keys to enable SSH (of atleast 768 bits size) to enable SSH v
2.
Authentication timeout: 60 secs; Authentication retries: 3
If they do it manually, it will take it..
Domain name is set and everything else is set.
Need to know why it is not working. This is an impact to operation.
RO
Joe Clarke Thu, 11/05/2009 - 21:46
You're missing the word "end" at the end of your config snippet. Try:
end
