VPN Client IPSec Authentication Using Digital Certificates
Nov 5th, 2009
Dear all,
I would like to ask you some question about VPN client wit Digital certificate, now i had ASA 5510 and using VPN site to site, VPN client and SSL,
So would like to use VPN client Digital certificate,
what requirement that i can do VPN client digital certificate?
when i implement VPN client digital certificate it have problem with VPN site to site and SSL or not?
Best Regards,
Rechard
Todd Pula Fri, 11/06/2009 - 07:53
The doc below gives a good overview of certificate authentication for IPSec VPN clients on the ASA. Multiple authentication methods can co-exist on the ASA platform so you should not have problems with your L2L tunnels using pre-shared keys. You will need to consider how you want to manage certificates in your environment. This can be done internally using a Microsoft CA for example or through various 3rd parties such as Verisign.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008092d8f1.shtml
rechard_hk Tue, 11/10/2009 - 19:00
Dear Topula and all,
Thanks you for your info and link that you show me, so i would like to ask some questions about implement VPN client with certificate.
1- what requirement for implement VPN client with certificate?
2- i would like to know the first step for create certificate for VPN client? or just follow some step on your link it will be working?
i never use it before!!!!
Best Regards,
rechard
