connection logs
suthomas1
Level 6
Level 6
WOuld need advise on the attached logs from a connection , obtained by tcpdump on a firewall.
46.56.76.34 is the global ip of ours which is been NAT on the device. the private ip for this hosts a website, which is inaccessible.
202.94.66.21 is the internet ip used to check if the site is reachable.
Please suggest what does these logs indicate.
Thanks!
iyde
Level 4
Level 4
Hi Sunny.
Probably the Security > Firewalling forum might be a better place to post this question.
HTH, Ingolf
