asdm unable to open
Nov 6th, 2009
one of our clients are having problems with using asdm for firewall with version 4.0 and asdm 6.1.
Am using java jre 1.4.2_6 version. It used to open earlier but now it hangs at login.
Please suggest.
Thanks!
Panos Kampanakis Fri, 11/06/2009 - 10:48
  • Cisco Employee,
Did you try upgrading java?
Does that help when running Java 1.6?
PK
suthomas1 Fri, 11/06/2009 - 22:10
Strangely, i cant access it now when https://ip address is used. http server is enabled for this interface already.Please advise.
I have another ASA which is accessible using the same Java.
Also, should it show the asdm image in the filesystem( this being a module fw).
Thanks!
suthomas1 Mon, 11/09/2009 - 05:26
Experts,
tried a telnet on https port to this firewalls ip, but it doesnt respond.
Any ideas.
Thanks.
duncan-blake Mon, 11/09/2009 - 16:23
If you can't telnet to the port, then you certainly won't be able to use ASDM to control it. Is there any chance you are having a routing or internal firewall issue? That is, what's the network like between your admin machine and the ASA?
Some other questions/techniques to try:
Is it configured for administation over SSH?
Can you connect a serial cable to the console port, or connect through a remote console solution?
