MARS GUI and the IE browser
dustinsuko Fri, 11/13/2009 - 09:24
IE6,7,and 8 work just fine. Are you trying to connect to a LC or GC? Have you installed the Adobe SVG Viewer? in the URL field are you entering https:// instead of http://? Just a few ideas
Dustin
Farrukh Haroon Fri, 11/13/2009 - 11:16
  • Red, 2250 points or more
Try clearing your browser's cache and adding MARS as a Trusted Site and enable pop-ups for the MARS URL (Add exception in IE). And the SVG plug-in is very important.
Not all steps are required, but sometimes can do the trick.
Farrukh
