1252 status blinks red,green,blue
Nov 6th, 2009
I'we connected a Cisco 1252 accesspoint to a 802.3af switch, 15.4w.
And it blinks red, green, blue on the status.
The accesspoint is autonomous using latest c1250-k9w7-tar.124-21a.JA1. 5Ghz radio is off/disabled.
but im still getting this in the logs
"Limited(1x3 MIMO) radio functionality due to insufficient inline power. To get full functionality use enhanced PoE switches, power injectors or power supply."
If i physically remove the 5Ghz radio the alarms go away and also the error message about mimo 1x3.
Is there a way to disable the 5ghz radio completeley through software?
dancampb Fri, 11/06/2009 - 05:27
  • Cisco Employee,
You just need to shutdown one of the radios, save the config, and reboot the AP and you should be able to get full MCS rates with 802.3af power. When I tested this in my lab I didn't get the low power warning. They key is you have to reboot the AP after disabling the radio.
Marcus Johansson Fri, 11/06/2009 - 06:20
The 5Ghz rasio is already shutdown.
Any other idéas?
Current configuration : 1657 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$XIx.$a9uUCWpvrJHHW60CT/VgE/
no aaa new-model
dot11 syslog
dot11 ssid TESTWLAN
authentication open
guest-mode
power inline negotiation prestandard source
username Cisco password 7 072C285F4D06
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid TESTWLAN
antenna gain 0
beamform ofdm
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid TESTWLAN
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
dennischolmes Fri, 11/06/2009 - 09:54
  • Gold, 750 points or more
Physically remove the 5ghz module. Sometimes the backplane of the AP doesn't see the admin down on the radio.
Marcus Johansson Fri, 11/06/2009 - 11:13
Yes, if i remove the 5ghz radio, it works fine!
BUT this can't be the solution??? -it's just silly that you can't completely disable the radio via software.
dennischolmes Fri, 11/06/2009 - 11:16
It is the solution...lol. You can order a blank to fill in sthe spot. Cisco will SELL it to you. hehehehehe
Marcus Johansson Fri, 11/06/2009 - 11:25
O my god! -Is this what the cisco technicians came up with?
Remove half of the accesspoint, mount the remaining pieces on the wall and it may work if you're lucky.
Couldn't they just added a on/off switch!
Marcus Johansson Fri, 11/06/2009 - 12:20
Found this on the cisco site...
http://www.cisco.com/en/US/docs/wireless/access_point/1250/installation/guide/125h_c1.html
Power Sources
The access point can receive power from a 1250 series DC power module or from inline power using the Ethernet cable. The access point supports the IEEE 802.3af inline power standard and Cisco CDP Power Negotiation. Using inline power, you do not need to run a power cord to the access point because power is supplied over the Ethernet cable.
The access point supports the following power sources:
•Cisco Aironet 1250 series DC power module (AIR-PWR-SPLY1)
•Inline power:
-Cisco Aironet 1250 series power injector (AIR-PWRINJ4)
-IEEE 802.3af power source (access point with only one radio module installed)
dennischolmes Fri, 11/06/2009 - 13:25
LOL... See I told you!!! Its because the unit is modular that it requires 802.3at. Notice the T. LOL Now give me my 5 points for solving your problem!! ;) just kidding. Good luck man.
