LMS 3.1/ more that files .lic that usual.
Answered Question
Nov 6th, 2009
Hello, dears all,
I have retreived the license files from an installation .
There is 3 other files, surely, corresponding of the database licenses.
Unfortunatly, there are not readable .
Do you have an idea ?
Richard
Correct Answer by Joe Clarke about 7 years 8 months ago
Yes, the database licenses must NOT go into NMSROOT/etc/licenses. If someone moved them there, that was wrong. They need to live under NMSROOT/objects/db (the specific path will depend on Windows vs. Solaris).
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 11/06/2009 - 10:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What files? From whom did you receive them? What are you trying to do with them? All of the *.lic files under NMSROOT/etc/licenses are LMS licenses, and they are in ASCII text.
richard.tetu Mon, 11/09/2009 - 01:40
Hello, the end-user has scheduled to upgrade to LMS 3.2 in a next future. We are wondering together what were theses files.
You can see them in the attachements that i have posted (I beleived that theses 3 last files are for databases , but i would like to be sure) I didn't see them by the past .
I think that it's in relation with the fact the ODBC has been opened in 3.2
Martin Ermel Mon, 11/09/2009 - 03:56
  • Blue, 1500 points or more
that is correct the last 3 files are the license files from Sybase SQL Anywhere:
dbeng10.lic SQL Anywhere personal database server (dbeng10)
dbsrv10.lic SQL Anywhere network database server (dbsrv10)
mlsrv10.lic MobiLink server (mlsrv10)
They are not human readible and are used by the dblic tool.
I am wondering about the location of these files...
I checked the location for these files on a fresh LMS 3.2 installation (Win2k8) (- no update-) and they reside in NMSROOT\objects\db\win32 and not in NMSROOT\etc\licenses.
Do you know how these files did go into this directory?
Correct Answer
Joe Clarke Mon, 11/09/2009 - 08:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
richard.tetu Tue, 11/10/2009 - 00:49
I don't think that theses files were moved into this location.This install is a LMS 3.1.
I take some informations from my end-user
and i will post it under the forum.
Thanks.
richard.tetu Fri, 11/13/2009 - 07:21
Thanks Joe, I get my answer now. Theses files should not arrive under the
/licences directory.
When, an upgrade has done does they need to reinject into a fresh install too , in a LMS 3.2 ? I read in the user guide of administration of LMS 3.2, that restore of database has taken part of the initial size of the previous one ( in this case , the 3.1 files)
Richard
Joe Clarke Fri, 11/13/2009 - 08:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If they restore a previous LMS 3.x backup into 3.2, the license files will be migrated automatically.
