ASA Clientless VPN Portal question
Nov 6th, 2009
Hi all,
I have an ASA on which I am trying to use the clientless SSL VPN Access option with a customized login page.
I want the user to go directly to an internal website from a sucessful login but they always get an interim ASA page with a dialogue box asking them to click the continue button to go on.
My question is how do I turn off this interim page so that the user goes directly to the internal website from the logon page?
Overall Rating: 5 (1 ratings)
hdashnau Fri, 11/06/2009 - 08:29
  • Cisco Employee,
This may be the solution:
1. Check "show vpn-sessiondb webvpn" to see what group-policy is assigned after login.
2. In that group-policy set the homepage value to your internal site:
group-policy attributes
webvpn
homepage value
If you already have the homepage set and you are getting an additional prompt, please post a screenshot of this prompt so I have a better idea of what component is causing it. Also provide your config if possible.
-heather
allissrcco Fri, 11/06/2009 - 08:45
Hi Heather,
Thankyou for your reply to my post my homepage was already set; but what I did notice was the attribute 'banner value' which was set. when I removed this attribute the interim page disappeared.
Thanks for prompting me to look in the right direction.
Richard
