CUE Editor and ephone-dn busy
Nov 6th, 2009
Hi to all,
I have this little problem, I create a simple script .aef for CUE using CUE Editor, in the script I put a "Call Redirect" function and I configure the "Busy" option to play prompt and do other things. But it doesn't work as I want because when the call is redirect to the number and it is busy, the call are redirect on ephone-dn setting "call-forward busy", what's is wrong?
Thank you very much
Augusto
Overall Rating: 4 (1 ratings)
paolo bevilacqua Fri, 11/06/2009 - 07:12
  • Hall of Fame,
    Founding Member
Nothing is wrong.
If you configured CFB, CME will send the calls where destined, and CUE cannot do anything about it.
