HTTP 1.0 & HTTP 1.1
Muhammad Khan
I have 3 webservers running Linux being load balanced using Cisco CCS 11501 with SSL termination.
previously these servers were being load balanced using "Pound" load balancer and all worked well.
Since replacing "Pound" with Cisco CCS any clients connecting using http 1.0 see a blank page, whereas clients uisng http 1.1 connect just fine.
I am wondering if that is somethingto do with CCS or Server side needs some reconfiguration?
Gilles Dufour
The CSS does not care about the version normally.
Do you have a sniffer trace of frontend and backend ?
What version do you run ?
G.
Hi gdufour,
Thank you for your reply
I have attached front end sniffer trace with CCS installed and I can see Http 1.0 is being reset.
Also attached are the details of previous setup. I suspect it is back end port issue?
